Rob Cowell
- Nov 15, 2011
Not really a lounge subject but hoping for any ideas. From anyone.
So I found an issue with a wire between the airbag bits in my steering wheel and the central airbag assembly (ECU sort of thing). Have replaced the wire and the error code I was getting has been replaced by a different one.
To diagnose this I need to "release the airbag activation prevention mechansim built into the connector on the central airbag assembly".
How hard can that be? Here are the insttuctions.
And here is a photo of the same connector, #1 above.
When the connector is plugged into the airbag central assembly there is no continuity between pairs of pins. The pairs are the same as the pairs of short springs you can see in the picture. When you disconnect the connector there is continuity. I assume this is the short spring creating a circuit.
You can see how narrow the terminals are for the pins. It's quite hard to cut strips of paper that thin. I used a train ticket which at least supports it's own wait for inserting into the terminals. Now it's not clear to me where to insert the paper. I've tried in the holes shown greyed out, and the holes below which is where I think the pins from the central assembly go. But neither of these break the continuity between the pairs. I've also tried using a cut down tie wrap in case the spring needs a bit more oomph to get past it.
Bit stuck now. Any ideas? Anyone done this before?
