- Mar 1, 2010
Just read the FWM which confirms what you say but still confused. If the refrigerant in the sight glass is in liquid form does this liquid mix with the oil to become one liquid ? Or are the two not miscible ?
I take it refrigerant = gas. If the A/C is not running and the car has stood overnight the gas pressure should be equal throughout the system. If the gas level is low the only way to increase it is to add more but surely the pressure would increase?
The FWM says if compressor, evaporator, condenser or drier are removed these should be drained and the oil measured and an equal quantity returned to the system plus a bit more I suspect as it is impossible to get all the oil out of the old parts.
My genuine Denso/Toyota seals have arrived but I'm too tired to look in the box .
