Compared to say a hitch mount this would work quite well and similar to a front bumper mount. Neither are ideal but real world usage should be fine unless you need DX comms. As Crispin says the higher up you get it the better, partly to reduce the masking effect of the roof structure and partly to reduce ground losses. The vehicle is not a ground plane, it is a capacitive coupling with the ground [plane]. The poorer / lower the mounting point the more current returns through the ground plane rather than the trucks steel body causing losses, this on top of changes in the antennas resonant frequency that also cause losses. Also the real world distortion of the radiation pattern caused by not being in the middle of the truck is minimal, what really matters is getting it as high as possible, that's the main reason middle of the roof works best, but off to one side is barely any different.
