Jureb
- Dec 29, 2020
My power antenna in my 2002 Prado (95 series) is broken. Previous owner told me that a thief had broken it. The aerial mast is gone/most likely broken inside the antenna unit. The unit itself wiggles around and probably the mounting bracket / screw is broken, I don't know I still haven't looked inside to check the situation. I'm probably going to buy whole new antenna unit.
The antenna cable which goes from the antenna unit to the radio inside the cabin comes with the antenna unit - you can't unplug it. That means I will have to guide the new antenna cable from the fender to the back of the radio? Guiding that cable seems like a major pain in the a**. Did somebody already do this? Any suggestions? I am also going to look into aftermarket antennas, the manual ones. Does somebody know any good aftermarket manual antennas that would fit in that standard Prado antenna spot?
