Not an expert on injectors noooo waay, but having swapped out several sets now and been at the testers when they went on to the rig to be checked, I can say that generally the 80 will run on knackered injectors quite happily and doesn't always improve noticeably on perfect ones. Sorry Mr T but it's a clunker of an engine designed to run on snake bile and monkey's f****y batter.
Injectors wear due to the passage of high pressure fuel through them. They can also block of crud gets through, but 'my man's' view at the injector place is that cleaner etc is hogwash. They don't gum up, they wear out and the most important bits, inside the injector body, not the tips are where problems are more critical. Possibly lubricating these springs and shims in there is more important than the tips. I have had a truck running perfectly other then lost of white fume, pulled the injectors, have them tested and saw fuel pour out of them like a punctured hose pipe. I had them re tipped and the fume went. There was not other noticeable benefit really. Recently I swapped mine again in this engine. The tips were perfect (I had them tested that week) and if anything my truck seems down on power. Probably sue to the fact that not so much fuel is pouring into the cylinders. I pulled Matt's 'jectors, had them tested and they were appalling. Put in the good ones and does it run that much better? Not according to Matt but it doesn't smoke any more.
So verdict - don't waste money on injector cleaner. They aren't blocked. If it's running leave it be unless you get 6 mpg.
As for lubing the pump etc, well I'd get a pusher pump to take the strain off the old lift pump for sure, mine certainly seems happier not to have to be sucking so hard. Will adding 2 stroke help or harm? I'm not the expert on that. But watching with interest. Fit an intercooler that's my solution to it all. Sod the science, give it some whoaaah!
