Lorin
- Mar 28, 2010
My gearbox shifts and works as it should, maintaining approx 80 degrees C in most operating conditions. However, I've noticed that at a constant 70mph it slowly goes up to 110 degrees and will stay there. If I drop back to 60mph the temp will slowly fall back to 80 degrees. It does this irrespective of the ambient temps.
Any ideas what could be causing this? The gearbox has an extreme valve body and the ATF was recently changed to Castrol Transmax Z fully synthetic and is it at the correct level (the temp issue was happening before the fluid was changed). The torque converter lock-up is working as it should, engine/coolant temps are in the normal range and the transfer box isn't getting hot. The gearbox cooler has also rccently been flushed and is working as it should,
So I'm stumped! I am running larger tyres but the truck is regeared and the truck isn't carrying much weight. Does anyone have any ideas what else it could be?
