auto box output seal ...
Red Oktober
think thats what is leaking anyway ....
question is though ... should i get this sorted asap .. or is it ok for a bit
That's the transfer box rear output seal gone Carl, not a 2 minute job but not a major one either so long as the bearing is ok which it probably is :) Should be ok for a while unless you go wading in deep water and keep an eye on the oil level in the transfer box. I might have a cheap OEM seal for you if you PM me your VIN so I can check the part number ;)
Have a look at this thread from the FAQ: viewtopic.php?f=15&t=11718
It may also be worth checking/replacing your speedo o-ring... couple of pennies (got mine from a local hydraulics specialist) & a 5 minute job. Whilst the chances are its your rear output seal - a dodgy speedo seal can also produce a drop or two in this area...
