Ecoman
- Sep 8, 2010
Ok ok thanks for the advise, is it ok to run attainted inside the cab the yeah? Thanks
Again I wouldn't run it into the cabin, unless you like the smell of warm gear oil
As Clive says, just run it up to the bulkhead just under the bonnet. If your that deep that the water is over your bonnet then you have worse things to worry about than a bit of water in the axle casings!!
