- Feb 2, 2013
ABS ring is covered in grease , my fault i used too much while resetting the bearing last time but i can't quite picture how deep i have to go to wipe the ring clean ?
Not sure how much time i have today so does the shaft have to come out or will i get to it by just removing the wheel bearing again ?
I could probably clean it from the sensor hole with patience a screwdriver and brake cleaner spray , but i'm not sure what the spray will do to the grease i need in there and besides to much is to much so it will only find its way back onto the ring .
Live and learn
Live and learn
