Hey guys, so after reading on the forum it seems my 04 lc120 does not have obd2 and that is the reason my elm 327 scanner won't connect to my torque app.
Can you guys recommend a cheap obd1 bluetooth scanner that works with the 04 lc120
It's a bit fiddly to use if you don't have 32 bit Windows, but it can be done. If you're stuck on that bit I'll dig out my old post on it. Might be on the other forum.
