BIG clean GREEN
Hi all,
Last weekend Battered and Blue and myself did a 1.5" body lift on my LWB prado Auto, everything seems OK other than the position of both gear levers, the low ratio gear lever now vibrates on the plastic surround tray, which after taking a look underneath appears to be a relatively simple fix by shortening the linkage, however the main gear stick reads that you're in a different gear on the panel at the side of the lever to that of the actual gear as on the display within the dash, eg when the gear stick says you're in N you are actually in drive, has anyone else had and over come this issue ?
Thanks,
Nick
Thanks,
Nick
