The smaller pipe handles a higher pressure (3,100 psi) than the larger (1/4" or 6mm) pipe (2,250psi).
Fluid is incompressible, so gives a direct connection between master and slave cylinders. if the brakes are in good order you won't need to pass volume through the pipe.
I ran my pipes through neoprene tubing where they pass over the chassis to reach the Load-Sensing Valve. That was just a precaution against chaffing.
