Nice one...J66P said:collected my Cruiser after having its lpg kit fitted today
chadr said:did you go for a flashlube kit? When my BRC system was fitted (I didn't own the car at the time) the fitters had said that the 5VZ-FE didn't need it.
J66P said:chadr said:did you go for a flashlube kit? When my BRC system was fitted (I didn't own the car at the time) the fitters had said that the 5VZ-FE didn't need it.
Guy that did mine said no point on this lump
Seems to be working JW - what are the symptoms of failure??Jon Wildsmith said:There were problems with the 'Mk1' Flashlube electronic kits, I had 2 fail on me, but the updated replacements worked and AFAIK are still working? Prins may be running into the same design problems as Flashlube did.
