You can get a replacement from Milners but it's the whole unit, just double check over the phone that it will accept the bulb holder. It depends what they have in stock at the time, I ordered from the website a pair and 1 had the lamp holder cutout and t'other didn't.
One side of the fitting kinda hooks into place and then held in with a nut on stud on the other side. In theory undo the nut and the unit will pull out, however the stud will probably turn in the fitting and you can't get the nut off, I'll chop mine out when I get some time.
