- Mar 7, 2010
Today I decided to change the light bulbs illuminating the bottom row of switches in the centre cluster (rear demister, mirror heat & rear heater). I have the bulbs from my 2000, and thought they would fit. Here is a pic of the kind of dash I have:
After opening up :
1 - pulling out the two side panels
2 - four bolts for the centre part with the radio
3 - detaching 8-9 plugs
4 - six screws for each supporting bracket across multi display - radio - HVAC controls
5 - four screws for back cover of the hvac & bottom row switches
6 - two screws for the little narrow pcb for the four switches
- I found bulbs that look like they are soldered onto the pcb. And it looks like all four of them are blown, according to ohm metering (no reading). Now, did the designer decide that these would never blow? Or that we have to change the whole pcb, with microswitches, leds and bulbs?
The bulbs for the hvac controls are the more normal type which you twist 30 degrees and pull. About 1 W (11-12 ohm) green bulbs. On the 2000 these bulbs are black, while on the 2004 they are pink. The colour doesn't seem to indicate any difference though.
Do you have any experience with this?
(I'll see if I can add some photos here)
After opening up :
