Lorin
- Mar 28, 2010
Another spanner in the works
"Quick Question - Is your 80 Series Part time 4wd, or Full Time 4wd?
The Full Time 4wd 80 Series have driveline vibration issues at 4 Inches of lift, so a Part Time Kit will also need to be installed."
I think i'm correct in assuming a 97 UK spec Amazon 80 is permanent 4x4 and if so i absolutely do not want part time 4x4 ,
I'm thinking well others have a 4 inch lift so is it really necessary ?
Some people have no driveline issues at lifts of 4” and above but more than that do, hence why a 3” lift is generally considered to be the optimal lift for an 80. It is why Slinky kits only go to 3” and why respected LC experts such as Slee will include a DC prop shaft with their bigger lift kits - Oz sellers tend to recommend the part time solution.
Chris’s question is the big one really - why go that high? 3” is enough to run 35s or 37s with a few supporting mods. Anything more than 3” tends to lose not gain articulation. You will also have to start looking at adjustable Panhards.....
