OK, I'm no expert on 100's to say the very least, but I do have an 80, but it's a manual.
Please try to get it out of your head that you are switching in and out of 4x4. It's 4x4 all the time.
What you're doing is locking or unlocking the centre differential. When unlocked, the front wheels and the back wheels can rotate at different speeds, when locked they rotate at the same speed.
With CDL you will feel a scrubbing, but not so violent as yours sounds, IMHO.
What you describe sounds like the rear locker is engaged, meaning the rear left and right wheels will be rotating at the same speed. When you corner, especially on full steering, normally the inside wheel will literally skip, this is violent on dry asphalt, which I'm sure is the norm where you are.
I'm not sure whether you will have a rear diff lock, but you may have a limited slip diff. It could be that which is giving you problems.
