I've got the CDL dash switch and it operates on H and L range. On fitting it, you disconnect a plug on the transfer box. I think there is a thread on it on this forum.
It's best that you cover the plug you remove to protect it from all the road grime. I cut the thumb off a pair of rubber gloves and fixed it with a cable tie. Trouble was when looked the other day it had perished, I guess because most stuff is biodegradable now. So, will probably use shrink tube or something
