Center diff lock inoperative
rmurphy5
Hi guys, my centre diff has stopped working. It is definitely not engaging rather than the switch being faulty. Which pins on the plug to it power it? I hear the relay click in the passenger footwell but no noise from the actuator at all. It did work well until recently. I just want to check the loom before I take it off.
Thanks!
The diff. fuse powers only the actuator motor, not the relay. So if you have a footwell click, the diff fuse can still be blown.
You have listed your 100 as 2003 -- There is a difference between production date before and after august 2003 -- It's the production month which decides which diagram to look at, but for this issue, I can't see much difference.
  • cntr dff ewd.pdf
