janokresik
- Jan 15, 2025
2013 LC- just got it. Never owned a 4x4.
4x4 service was done by previous owner at 75k.
First month of ownership had to replace the radiator due to a “common” problem causing a crack. Second month replaced struts, brakes. Then….
Was driving on snow and ice at low speed, switched from H4 to L4 - if the change happens in neutral but rolling around 15 mph, what can happen?
The 4lo light started blinking, then next day engine light came on.
Toyota dealer ran codes. Said code referred to master brake cylinder and gas cap. Recommended replace MBC. They Reset the codes. Replaced gas cap since it had old seals- (can set off the 4lo and engine lights)
No lights are on. Seems to be running great. How do i know if brake master cylinder is needing replaced?
The Toyota dealership came to the conclusion to replace MBC by deduction only. Did not visibly see any signs that it needed replaced.
I would love input to help me decide whether to replace it.
