Rob Cowell
- Nov 15, 2011
So this relates to my Jimny, not the Land Cruisers but there are a lot of helpful people here much smarter than me so...
Twice in the last month the Jimny has failed to start. The starter motor / solenoid makes repeated fast clicks. Sort of what I'd expect if the battery was duff. But the battery is good. About 3 months old. 12.8V across terminals, and charged to make especially sure.
First time this happened was at home, so ignored it for a couple of days. Went to investigate and of course it started first time!
Happened again last week in the village. Got Mrs C to tow me as far as a slope, then bump started it and got it home. Have used it a few times since just bump starting. Decided today to have a proper look at voltage drop with the multimeter and of course it started first time! Pulled the fuel pump relay and took some readings with my assistant holding the ignition on; between battery positive and solenoid input, drop of about 0.15V. Between starter motor and battery negative, about 0.01V drop.
So I don't think I've got any voltage drop to worry about. Only thing I can think now is the contacts in the solenoid are failing. But would they do that occassionally, and then burst back into life after a few days? When Suzuki build the Jimny they start with the starter motor and then construct the rest of the car around it. It's a pig just getting a multimeter probe near it, so if it has to come off I might as well put a new one on for all the hassle it will be.
Any thoughts?
Any thoughts?
