hi guys,
i tried turning lock diff on and there were cracking noises, is that normal? Had simillar noises when ibwas breaking on ice and the car was sliding.
Thnx
Which Diff lock Archie? What surface were you driving on? What speed? Straight or turning? Did you roll the window down and see if you could figure out where the cracking noise was coming from? Could it have been coming from the front wheel area?
These sorts of things help the guys on here help you out.
The answer to your question is No, it's not normal.
But then you thought that, didn't you. [emoji6]
Now you probably want to know why it's making that noise? Well, it could be all manner of things, but if it's coming from around the front wheel area then it could POSSIBLY be CV joints.
Was it a sort of grinding clicking noise?
P. S i didnt say it right, not cracking noises but clicking noises. Sry
No worries Archie, it's easy getting the wrong end of the stick on a forum. It's often good to give a description of a sound 'it's exactly like spinning a bucket with a handful of gravel in it' something like that. Better still (and you being new here might need to get your posts up to 15 before the forum will let you do it) take a video to try and record the sound. Best way is to give as much info as possible.
Anyway no harm done. Tell you what, there's an 'introduce yourself' section on here, pop over there and tell us a bit about you and more importantly your truck. [emoji4][emoji4] once you get to 15 posts you can post pictures and we all like to see them. We're a friendly bunch on here and like to know a bit about each other and their trucks and say Hi and Welcome to the forum. [emoji4]
