J
jibberjabber
Your welcome, any time.That's great info. I can try to work a solution on the bottom part knowing that if I mess up I can always replace it cheaply. Thanks again!
I've just had a look at mine, are we talking about just the top lid flying open? or the lid and the tray flying open?That's great info. I can try to work a solution on the bottom part knowing that if I mess up I can always replace it cheaply. Thanks again!
If the part on the lid isn't going far enough forward, is the spring in the latch working?The part on the lid doesn't go far enough forward under the keeper on the box. Does that make sense? My explanation is bit clumsy.
So a new bottom latch will be no good to you, I’ll have a look at my lid tomorrow, but don’t hold your breath, as it must be difficult to get at or Toyota would sell it separately, I think you spring has lost some of it’s spring.It's only the lid that flies open. There is a bit of travel on the latch but it may well be the spring which is goosed as the latch doesn't come far enough forward. Is there a possible fix or is it a new lid?
Do you think it might be something to do with the rainFunnily enough the squeak isn't there today. The plot thickens!
Did you pinpoint where the noise was coming from? As sometimes water acts as lubricant so if the squeak was under the bonnet water may have gotten onto a steering joint under there.I was thinking that myself although I don't know why. Interesting!
Stranger things have happened at sea![]()
Back to the Console lid problem, I can now see why the latch is not sold separately, it's part of the lid molding so can't be got at without damaging the lid, as I said, the only thing I can think of if the latch is not coming far enough forward, is that the spring is worn, I was thinking about trying to oil it, to see if that would help, you can get small oilers with what looks like a long needle but is a small tube and the oil is very light, have a look on eBay.
The other thing would be, if you can't make the latch go further forward would be to make the receiver of the latch slightly smaller, off the top of my head, I was thinking of a small (smaller than the one in my pic) washer or similar on the top with a small short screw, or maybe use one of the previous posters suggestions, but what ever you do it would be a bodge job, and if it were me it would bug the hell out of me.
And better for your bank balance, I can't believe how expensive those lids are, keep your eye open for a used one on eBay.That looks a pretty good solution. Like yourself it would bug me but it is still better than the lid flying up all the time. Many thanks.
