- Mar 1, 2010
Checked and altered my injection pump timing. It was retarded. Now the engine is much more responsive to the throttle and the car is much nicer to drive.
I made a pump timing SST that screws into the timing thread in the pump. You do not need the Toyota one that brings the dial guage round the side of the pump and you don't have to slacken off the injection pipes. You will however have to take off the oil filter to give you direct axial access to the timing hole. My tool is just a dial guage extension which screws into the timing hole. It is a tube with a plunger incorporated and a screw to clamp the gauge at the other end.
The factory setting is 1.55mm whether or not you use the Toyota SST as with the Toyota one the fulcrum is in the middle.
When you drive your LC the pump timig is getting more and more retarded and after 100,000 miles will be out of tolerance assuming it was set right at the begining. So I guess most people have retarded timing on this forum's 80 section.
IMO those wishing to alter their pump settings should check their timing first.
Really pleased with the result.
Frank
Frank
