diff oil .
Garry
scotland
Hi
Good afternoon
Please can you tell me what type of oil to use in my vehicle as dealer not able to help !!! (Not suprised )
Model FZJ 80 Auto box ,3 difflocks
Year 1997
So do i use standard Hypoid Oil or Hypoid Oil for L.S.D. ??
many thanks
Garry
Garry
Transfer box takes 75w-90 and the axles take 80W-90.
But what LSD? If it has three diff locks it doesn't have an LSD.
AFAIK, the actual oil in a diff with LSD is the same as without, but there is an additive of some sort that is in it. Both axles take Hypoid API GL-5 but one will say for LSD.
Hi Chris
Thanks , I have a glut of Hypoid 80W-90API GL-5, but is marked LSD
and was trying to find out if it was suitable.
Garry
So the real question was can I put LSD oil in a normal diff?
I don't see why not. The gears going around in an LSD are the same as those in a std diff, but I would perhaps Google this more specific question for a definitive answer.
Hi Chris
Yes that was the real question , but i was trying see what other have been using .
Garry
Yes it will be fine. I was told by the chaps at Opie oils that as long as its GL5 and 80w90 or there abouts then it will be fine. I was going to order a load of oil but when I told them I had a load of LSD oil of the same spec for my hilux they told me to just use what I had and not to waste my money. :thumbup:
