warrenpfo
- Jul 21, 2010
I hope to drop, inspect, split and clean both drive shafts this weekend coming and just wanted to ask if anyone had done this.
I know I need to mark each shaft so that I get the splines to match back up when I put it all back together but that aside is there anything else I should watch out for and I take it moly grease for the slip joints and U joints?
I just think after 20 years a good clean and re-grease is in order as i also have a slight drive line "clunk" on slowing down and the car gearing down so just want to eliminate the shafts before i look at the gear change cable and other bits.
Perhaps a write up is in order
