JOHN OF LONDON
- Jun 13, 2016
Hi,
Just working out the wiring for an auxiliary battery and the existing wiring on the HDJ80, which looks original and undisturbed has me puzzled.
The (surprisingly thin) wire from the alternator appears to run direct to the positive terminal of the near (left) side battery. This is odd because its a long way from the alternator and it produces a nominal 24V when the starter works; though I am not sure that the alternator is energised when the starter is running.
It is obvious to me that the simplest way to wire the alternator would be direct to the other battery which only ever delivers 12V; but equally obviously I am missing something as I am sure Toyota will not have run a longer wire without a good reason.
Does anybody have any idea what I have missed in understanding the wiring?
