- Apr 10, 2016
I would be very grateful for assistance so I get this right.
I would like to install a 10 point fuse box to run 12V things in the front of the cruiser.
The stereo, aerial, rear view camera and a couple of small LED lights are planned.
Thanks to @Richard Turner I have a 10 amp dropper to provide the power. I would like to draw from a switched 24V supply so nothing can get left on by mistake. An easy solution would be to tee off from the cigar lighter as it is in the right area so I could fix everything behind the glovebox where it is dry.
Queries:
Is this ok for say 5 to 10 amps max?
Would i need a relay before the dropper?
Where should any fuses be inserted?
What wire gauge should I use?
Or if it is a bad idea, what should I do please?
Queries:
