Mojo
- Jan 29, 2015
Just spent an exciting few days in Sierra de Cazorla, driving gravel tracks, wild camping and hiking up mountains. Those heading to the SE of Spain should think about driving in and doing the north/south route over the top. Highly recommended.
1. Main map of the area, which shows a 478 km hiking trail the GR247 (red). Within this area plenty of trails to explore. You will need both a GPS and a local tourist map as Spain is not known for marking anything very well. Roads that are off-limits have a barrier across them. Plenty of small towns around if you need to find a hostal or stock up on some food supplies.
2. Some great wild camping spots. This one at El Tranco reservoir.
3. Quality of tracks very good. Mostly gravel and potholes. The remoteness 'if' things go wrong is the biggest issue. But then we all drive Landcruisers....
4. The high road over the top..at least 75-100km long.
5. Lots of cunning foxes around at lunch spots.
6. Crystal clear springs to stock up on water.
8. Best room with a view
