I spent quite a few years working in Russia, including the winters so have done a lot of cold miles. Never really done much to adapt vehicles but here is a couple of things we used to do:
1. As said before, get your screen wash on the continent, ours is rubbish. If it is really cold we just used neat vodka
2. Clean out all the autumn debris (leaves and stuff) from the nooks and crannies as they can get into the heater.
3. New coolant and a flush, maybe even remove rad and clean. Inspect hoses. I have always made small tarp for in front of grill as this also keeps the snow out of the rad as it can melt and refreeze overnight on the rad fins.
4. Loosen, grease and readjust anything you may need to adjust when things get cold (engine belts, hand brake etc) to save your knuckles
5. Sort any lights with moisture in.
6. Grease door locks and door rubbers with silicon. Including bonnet
7. Check spare wheel and run a higher pressure in it as this will drop in the cold.
8. If you have alloys, take them off and grease flanges to make sure they are not stuck on.
9. Make sure AC drains are clear
10. Spare wiper blades
11. Check batteries and charge them, maybe even insulate them with the stuff that roll mats are made of, i would certainly put something under them if they sit in a metal carrier.
This is just a normal list we used to do, there is loads more
