Hi, I am really hoping that somebody can steer me in the right direction please. The Fan Blower Motor in our 2004 - 105 doesnt work. It is the Fan blower motor under the passenger side dash that blows air out of the vents. I used to own this car and I sold it to a mate. He had it for three years and I've purchased it back from him with the blower motor fan not working. I just thought it would be a fuse or a relay and an easy fix. I have checked every fuse. And I have double checked and even swapped out some relays. I took the cover off of some of them to make sure they make contact correctly. I have also installed a new resistor ( $240 ) as from what I read this can be the cause of the blower motor not working. The dash switch seams to be working as the relays all turn on and off correctly. If I power up the blower motor fan with a jump wire it runs fine. I am not getting power through to the Resistor and I do not know why. I do not know what else is in this circuit or why I would not have any volts at the resistor plug or any power at the blower motor plug. Any advice you can give me please would be greatly appreciated.
