Omar LC5 120
- Feb 17, 2020
Only just bought my LC 120. 2003. Thought it would be a problem free car. But noticed when I drove it on the motorway the engine light came on after about 8miles of driving, light would turn off but would come up again on the way home, again after about 8 miles.
AA came and checked, they said it's injectors. Took it to a diesel specialist, they've said it's fuel pump related. P1228 fuel pump range
So this is a Bosch garage and his logged in the fault with Bosch technicians. Some have replied that it's the red green valves. I would probably think it too, theres no start issue or rough idling, just engine light and possible lack of power.
Cause I have AA brc, I'm wanting to make sure it's covered the right bit. Is it worth me putting in a reconditioned Lucas pump from Europarts or stick in the red green valves.
Fuel pressure engine light pressure control valves pump
Also would like to add that I've spoken to Toyota UK about this issue. Of the red green valves. They responded by saying very carefully that this is NOT a known or common or recall fault, but ' room for improvement from Toyota' so basically saying it's a known issue.
Also these valves cannot be bought separately from Toyota. Toyota only sell the whole pump unit, £1700+
So where is the best place to pick them up from?
