- May 26, 2014
Asking for me dad.
Does the body need lifting on the 100 to fit a replacement filler neck?
Asking for me dad.
I know on the 80 through experience Dervis...On the 80 its is Mike as I'm sure you know so would imagine the same for the 100.
He's not only replacing the filler neck. The tank and sump are also leaking, he replaced the AHC with pedders last year..I managed to replace mine without lifting the body. I did jack the body a bit to create a bit of space as already mentioned.
The problem with the '100' is that a lot of the bits are fitted to the body or chassis before the two are joined. Changing AHC pipes is a right pain.
Before:
After:
I had to put a couple of 'Rivnuts' into a body cross-member to retain the pipe bracket.
The job is a bit of a pain when you're lying on your back under the truck.
Bob.
