Rob
My dad currently has Goodyear Wrangler HP All Weather in 255/65/17 on his Navara and is sick and tired of getting punctures all the time from glass/screws etc. outside work. Seeing as these tyres are not exactly cheap I have suggested that he gets an all terrain for the same or less money in a larger size as they will probably last longer and will probably puncture less frequently. I was thinking 265/70/17 as it seems quite common and looking around the new General Grabber AT has my attention as they are cheaper than what he has already. Seeing as most of his use will be on road I would not recommend the AT2 or BFGs as they are more expensive and will probably have a larger impact on fuel consumption. Does anyone know if the General Grabber ATs will be less prone to punctures than a road tyre? Are there any other tyres that I should consider that are tougher than your average tyre and are less than £150 fitted? Toyo open country maybe? Or should he just get the cheapest road tyre possible as these tyres wont reduce the amount of punctures he is getting?
