I'm sure i've seen a similar tool for boiling a mug of water a whole lot cheaper than that
I know Clive, I know…
Yes. Only no microwave.Its basically like a microwave for metal.
Can't wait to see you getting those bolts of that rust old petrol tank Shayne.
2 miles away should be safe enough I'd think.
BTW video recorders only work when you're out. It's well known that a watched VCR never records. I used to record stuff so I could play it when I wasn't in.
I see ..... so its like a blow torch .... but not as good
Stick it on with a g clamp, then use a plug in timer switch, plug it in and go to the pub, if no explosion after timer activates, return and undo!so if i plug it in near an open window and get a long stick .......
Same as dinner in a timer oven then?Stick it on with a g clamp, then use a plug in timer switch, plug it in and go to the pub, if no explosion after timer activates, return and undo!
