- Mar 1, 2010
I have not reread the thread. Are you sure the UJ's are greased properly? Grease needs to come out of all four legs of all four joints. Usually there is a lazy one on each UJ. Tranny noises are very difficult to track down unless there's an obvious cause or something fails. Also take the geae nipples off the sliding joints to relieve any pressure that may be in there.
I had a terrible noise on a car I rebuilt. Vibration and terrible noise throughout the tranny at anything over 40 mph. Everything had been stripped. Axle prop shaft gearbox etc etc. I swapped everything one at a time from a car a friend had in bits and nothing made any difference. I was lying under the car in a depressed daze for hours when I noticed the rear flange on the gearbox was pointing toward the ground, which it should do but the diff flange was pointing down also but should have been pointing up toward the gearbox. The 4 trailing arms had the same part numbers but when I got them off there were 2 short and 2 long. By some fluke I'd put the long ones on the top and the short ones on the bottom. Bingo and silence ! When I checked the release sheet from the factory there was a typed paragraph after test drive which said. "Manufacture and fit 4 trailing arms to rear suspension to correct alignment of rear axle ". Obviously that car had the axle points or chassis points welded in slightly the wrong place.
