Hello All,
The child lock is stuck on the rear off side door and as I'm getting a bit fed up looking like a chauffeur I think it's about time I tried to fix it.
The little plastic lever got stuck in the lock position, I jiggled it about to try and free it and the lever bit came off and fell down inside the door [emoji22]
The locking and outside handle all work fine but the child lock is still on[emoji35]
Anyone else had this problem? I'm assuming that something is jammed in there. Child locks can't be that complicated, can they?
Anyway I was going to have a go at removing the door trim to see what's going on in there. Bought myself a set of plastic trim removing tools, better than using a screwdriver. Just need a dry day at the weekend to do it.
Any advice gratefully received.
