- Feb 2, 2013
I have a swb 90 with steel 16x8 zero offset wheels and 285/75 R16 cooper stt tyres . No lift at all just trimmed the seam and mudflaps . Tyres touch the chassis on full lock . I think a spacer will cure this though i expect it will also mean i will have to trim the seam some more . The trouble is the only way i can test for what size spacers i need is to buy a set and hope a get lucky .
30mm wheel spacers seem quite common and should definately cure the rubbing on chassis but i'm inclined to think a 30mm spacer will mean the mudflaps will have to go altogether and trimming the seam further will not be enough . Besides this 30mm will put the treads outside my guards which will destroy the body paint .
I am on the verge of buying 20mm spacers and just hoping for the best but before i do i'd be grateful for comments and suggestions from those with experience .
