Thanks Chris,This is what is in the "max ellery manual"
BRAKE FLUID REPLACEMENT.
1. Thoroughly clean master cylinder and especially around wheel brake line connections
2.Disconnect wheel brake lines from master cylinder and remove reservoir cap
3.Allow master cylinder to drain until empty.
4.Fill master cylinder reservoir with new specified brake fluid,do not allow fluid level to drop below half full
5.Allow fluid to flow from open connection ports until fluid is free of air.Collect discharged fluid in suitable container then discard,do not allow fluid to contact paintwork.
6.Reconnect wheel brake lines to master cylinder and torque flare nut.
7.Drain brake callipers as follows
(a) Raise vehicle and place on stands
(b)Mark position of wheels to hub and remove wheels
(C)Loosen left hand front calliper bleed screw
(d)remove left hand calliper anchor plate retaining bolts
(e) Hold calliper upside down and remove bleed screw to drain contents of calliper into suitable receptacle
(f) Hand tighten bleed screw and install calliper assembly
(g) Torque anchor plate retaining bolts
8. Repeat step 7 for remaining calliper assemblies
9. Drain cylinders as follows:
Remove cylinder as described in "Drum brake -Wheel cylinder "section. Allow fluid to drain and install cylinder as previously described
10. Bleed brake system as previously described.
11. Install road wheel to original position.
Now I can just about follow this and half understand why as I suppose it is removing all the old fluid but it just seems a bit of overkill and a sure fire way of getting air in somewhere,
What do you think
or
ps. no mention of a LSPV Though Andrew, is the prado different as this manual is supposed to be for the prado
