Nick, I am presuming you have the FSM?
Nope afraid not. I've been trying to get one for ages but haven't found one
The fact the fuel gauge drops to zero on shut off but doesn’t move or drop to zero when you change tanks just adds weight to my theory.
Its reassuring that I don't need to worry about broken cables etc. Just got to find this relay. Now Amy's back from London we can try to listen for clicking, although presumably depending on which part of the relay is broken it might not actually be making clicking noises?
I had a look in the location mentioned in post 28 but could only find this
which I think is a Servo motor(?) and probably not connected to the fuel switchover (A/C maybe?)
Interesting I also noticed this
It doesn't show on the photo but the connector joins to the block that the other cables from the switch join to. Theres loads of un used connectors in my 105 because it is a very basic model, but this one has dirt on and looks like it might have once been used. Its a long shot but i'm wondering if at some point someone has removed something (like a relay module) and forgotten to put it back on (she has after all spent a lot of her life in Africa as a service vehicle for a water company).
I found a part number for the 'switch - fuel control' mentioned in post 28 and they are £35 on Amayama. Unfortunately there isn't a photo but I might pick one up. If it is the part it might at least help me know what i'm looking for.
I did think about putting in a separate fuel gauge, but I like to keep things as close to the base build as possible so that I don't inadvertently make more problems than I solve. I don't mind adding electrical things on the leisure battery side but don't like changing this on the factory install side.
Anyway thanks for all your help on this so far chaps. The search continues...
