- Feb 2, 2013
Just so you know your truck is permanent 4x4 so the little lever just gives you low range gearing and a centre difflock .
Rocker cover i'd just tighten . And the steering can seem a bit weird even when everything is definitely new and tight , seems to warm up and improve , or maybe you just get used to it ?
Old racks leak , probably because nobody ever changes the steering oil , but they never actually fail . Lower ball joints are the thing to check for play as your gonna crash if they fail .
