Beau
- Jan 28, 2011
Hey Guys,
In the process of wiring up my pump for my auxiliary tank but have a couple problems.
So basically I have a simple two way switch running the pump currently which works fine, wired in on Ignition. I want to use a 12 volt light so that I know when the pump is on and off. Light on = Pump working and vice versa.
I've tried running the wires in series, but then the pump does not work, but the light works as it should off the switch. I've tried running the light in parallel and this works, both light and pump, however the light is on constantly and only switches off when the pumps in operation. No matter what I do, I can't manage to have it the other way round...
Hoping someone can help me out...What am I missing?
