We get our new pup on Saturday...
(Ridgeback royalty). My drive is on an off-camber slope so when the gates shut there's a gap at the bottom that I use some fairly strong rubber matting (attached to the bottom of the gates) to close off. Else pup could sneak out
Current mat strip is knackered, and I wasn't concerned because Khubu could never get under there now:
Any ideas where to go for some fairly sturdy rubber strip - about 300mm wide, 3mm thick or so and about 5 metres needed? Can't seem to find what I need. I suspect thin conveyor belting might work but I don't need 200metres ...
