hole in my air box
Chas
Yesterday when taking out my air filter I noticed an elongated hole about 2" x 1/4" in the bottom of the air box near the edge, obviousy original, so why is that there, :?: the hole would let in water from the bottom anyway, so what is the point of fitting a snorkel. :confusion-confused:
Re: Fitting snorkel question
sounds like you're missing the rubber bellows that go underneath that hole if I'm remembering correctly Chas.
'There's a hole in my airbox, dear Chazza, dear Chazza... There's a...' Ah you get the drift :mrgreen:
I'll try & get a pic of Muxley's for you later on Chas :thumbup:
Hahahaha, thanks Gav, a pic would be good. :thumbup:
Chas,
I think you should have a clip-on metal dust collector bowl and rubber or felt gasket under there - I'd stay out of the deep water until you've rectified that!
All the best,
Toby
1990 HDJ80
1994 HDJ80
The airbox on my 90 also had a couple of holes in the bottom. Not sure why they were there but I just siliconed them up when I fitted the snorkel. I think there were a few others on the otherside who had done the same at the time.
The little holes are condensation drains. The big one on the 80 has a hinged debris collector under it (well, both my 80s did :lol:)
If they are condensation drains, should we be sealing them up? I had sealed mine up because there was some water at the bottom of the box after I had waded through some water. I had put the water down to spray within the engine bay that made its way into the tub via those holes. I have not had any water in the box since.
After fitting the snorkel I've sealed mine up! Just have a peep once a month when you do oil & water checks etc to make sure its all ok
yes its a dust tray when i fitted my snorkel i found it was full up
