I seem to have knackered my back so no work on the Cruiser today. I thought I'd set to and load some ammunition ready for a session at the range. Before anyone has a fit, no this is not giving away secrets to terrorists. Home loading of ammunition has been around as long as there have been firearms. You can buy ammunition of course but loading has its advantages. Not least that it's actually more accurate partly because it's more consistent and partly because you can tune it to your particular rifle. No two are the same and there are so many variables such as barrel harmonics etc. Even the weather can affect the ballistics. So, if you have ever wondered 'how it's made' here you go.
Firstly, the spent cases need some preparation.
The old primers (the bit that is struck by the firing pin) have to be removed
At the same time, this sizes the neck of the case so that the bullet will fit tightly in there. When you fire the round, the case expands in the chamber and shapes itself to the inside of the breech. If you are going to use the same rifle, then you only need to resize the next. Otherwise you waste energy expanding the the case each time you fire it. This also works the brass very hard and eventually the cases rupture. Not good.
Then we clean out the primer pocket so that the new primer fits snugly. These can swell and once the primer won't stay in there anymore, you have to bin the brass.
Next, we trim any excess brass from the neck. The case 'creeps' with use and gets thinner. All this brass has to go somewhere. So this trimmer is used to cut the neck and make it square again.
Next to allow the bullet to seat without scraping we chamfer the neck with this pencil sharpener tool.
New percussion primers are pushed in with this really neat tool.
So they look like this
Now we need to put the powder into the case using a vernier powder dropper. This has an adjustable chamber to allow for different loads and powders. This is a whole subject in itself. But it only gets you so close. Just tapping the table can affect the loose packed density in the chamber. Modern ammunition is loaded like this in factories, thousands of rounds per hour. This is as accurate as they get it.
We drop the powder into a pan to be weighed.....
And then topped up by hand to 1\10 of a grain. There are 7000 grains in a pound
Then into the case using a funnel
These are the bullets or heads. These are 100 grain, boat-tail soft points Copper casings filled with lead.
They drop into the neck of the case
And then we use a different press with a seating die to push the bullet in to a predetermined depth
In this case 2.64 inches
And here we are, 20 completed rounds. This is a basic reload but you can go nuts on accuracy including weighing all of your cases to batch them - the weight equating to wall thickness etc. You can tumble the cases in a vibro tumbler using crushed walnut shells to polish them. This ammunition here will easily group 3 shots into less than a pound coin at 100 meters.
Well, hope you found that interesting folks.
