stumog
- Oct 3, 2012
It's been stuck 1/3 up and had no reception.
While talking to nick he mentioned roughtrax do the sticky up part for £30 ish.
So when in there last picked one up.
Undo the metal lock ring I used a pair of water pump pliers but you could use circuits if you like.
Take off the black cover. it just pulls off.
Lift up the remains of what you have left and undoing the small lock nut from the wire.
Now set the new lock nut to the same amount of thread as the old one and twist the top of the aerial to do up.
Then just twist the lock nut tI'll it's tight.
Less then 10mins to do.
I have given mine a squire of oily stuff.
Some not so great pictures
