Does anyone have a wiring diagram (or sketch) for installing an IBS split charge unit? I'm actually more interested in the location and amperage of the fuses used. I've seen an IBS installation with 5A in-line fuses on each of the sensing wires, but none to protect the batteries..?
I would have thought you needed a 150A by each battery and a 20A feeding the rear Anderson plug? Also, some overlanders have used a 12V circuitbreaker which can easily be reset and you do not need to carry spare fuses which seems clever, but are they reliable in overlanding conditions?
Thanks,
Thanks,
