Tonytoyota2
- Oct 21, 2022
Hi Iwan that is one big job good that the dog is helping you will talk soon.
Well had a good going through both of the end connectors and looking back at some pics of the earlier 1kzte/2lte ecus the earlier 16 bit tech they are def 3 rows I think they were.. edit just found a 2lte mt and 1kzte mt ecu's and they are 2 rows. Maybe the 3 row is for the upto 08/04 which back then was their super new tech. Wouldn't be surprised that all the kzj120's remained on the old 16 bit ecus and wiring. Just before was looking through the fsm new features and (I think or gather) they progressed to the 32 bit ecu from that point.08'04.. hence the 4 pin deep sockets.Isnt rhat E10 connector from the engine ecu side?
So on t9 6 is black and red 7 is white and red, had difficulty in locating them in e10 but found a black orange on e10 14 with a reading .920 but when went for t9 to e10 21?? no wire there! Then I noticed the 3 pin high plug and the 4 pin plug...If you follow (by colour) the wires from the T9 connector can you see where they run to on the ECU? All you need to prove is low resistance on those wires end to end...
I seem to remember there were a couple of different ECU plugs from my unfortunate research on ECUs !!
This one seems to say that T9 pin 7 goes to E15(29) and pin 6 goes to E15(30)
So have great continuity t9 7 blue red to E6 29 also t9 6 white red to E6 30, t9 14 to ground is good too.. the locations are from the pin side of the plugs, was checking from the wire side which is like looking in a mirror!Hmm.. have a look over on the right hand side of this one - this one might apply to your ECU. (My ECU has got 4 rows on the pins as well!)
Does that look feasible from what you can see?
Also worth checking the resistance on that ground on T9 pin 14 while you're there.
Brilliant - keep going!! Good idea to run a wire from the battery to pin 1 - at least then you'll prove its the problem!
