Hi,
The sunroof is jammed shut. The roof lining/ carpet was soaking inside so I thought I would remove the roof lining check the drainage pipes were still connected. Drainage pipes were connected ok. I assume they are blocked hence water is over flowing into the car. I will unblock from the inside tomorrow. I assume to release the sunroof sliding panel is just the two bolts? I need to clean and re-grease the mechanism and guides.... That's the plan anyway
