Just changed my front rotor and bearing the groove where the ciclip sits is 5mm recessed from the housing making it impossible to fit had the whole assembly off again checked everything outer races of both bearings ate seated correctly. I have pulled the spline as far out as it can go, still 5mm to short. The rotor appears to be seated correctly I have measured the rotors thet are the same size as the old oned any help would be aprecciated
